Power tap location
fencer
FJRModel: 2006 *SOLD now 2018
x 215
x 274
Power tap location
Post by fencer »
What is the suggested location and wire code to tap into for a key switchable "on" relay for electronic add ons?
I used a running light in the tail on my 06. Now wiring an 18
x 6082
x 10031
Re: Power tap location
NOT the headlight. SMH.
fencer
x 215
x 274
Post by fencer »
Of course not a headlight Jason...
Where did that come from or did you f@$k up at one time
x 6082
x 10031
fencer wrote: Sat Sep 11, 2021 5:37 pm Of course not a headlight Jason...
I had a server power cable that I used to wire my fuseblock. Very convenient since all three wires are in there, just run the whole thing to the front. I tapped the relay wire to the headlight and didn't realize that unlike other bikes, when you switch on the high beams, the lows go off. Doh! It's still like that and I'm just used to tapping the cancel button on the GPS when it wants to turn off as I use the high beams. Been like that for something like 75K miles now.
fencer
x 215
x 274
Post by fencer »
Lol
That is why I used a tail light running light previously for my fuseblock
x 6082
x 10031
Yup, a better idea, I already had the wire running to the front. One of these days I'll switch it out.
x 914
x 2670
Glove box solenoid or auxiliary socket?
LED tail lights may not have 12 V for standard relay??
x 3430
x 12685
You can use a fuse tap in the Hazard fuse spot.... that holder is outside of the main fuse boxes....
You may be able to tie in to the licence plate light..... same as previous gen, two bullet connectors, blue is positive. Should be aft of the air cleaner, similar to previous gens.
fencer loved this
x 482
x 1312
Admore Lighting plug and play harness here. No taps, no splices.
