Spring Start Up
- ice station zebra
- FJRModel: 2008
- x 253
- x 150
Spring Start Up
For the first time in 12 years I couldn't start her up as normal. She's been sitting for four months in a heated garage with stabil and a full tank of ethanol free gas. Yuasa battery less than 12 months old. Couldn't figure it out. Fuel pump was priming. Opened up the air breather to see if a mouse house was in there, and nothing. Covered up the air intake briefly to enrich the mixture(?) and that did nothing. Checked the kill switch and looked for error codes. Nothing. Finally consulted the forum. ...Battery fully charged, leave on the tender, switch on and off 3 times. Switch on again, wide open throttle and bob's your uncle, she roared to life. This was the first winter I stabilzed with stabil. I ususally use seafoam, but a review I saw on Fortnine suggested stabil was better...maybe not? I think on my second tank of gas I'll run through a dose of seafoam thinking maybe the injectors need some attention and go back to seafoam next winter. Now I can look forward to going out for a ride tomorrow!
- x 910
- x 2660
Re: Spring Start Up
Flooded - happens occasionally. (Especially if the last shutdown was without being fully warmed up.) Wide open throttle to start and you might need a boost if the battery is anything less than excellent condition. I don't think it has anything to do with injectors or your choice of stabilizer. I have had this happen a few times in the spring but it always went eventually.
ice station zebra, FJRPittsburgh, and wheatonFJR loved this
- x 2355
- x 14497
Re: Spring Start Up
I've had that same "no start" scenario a couple of times over the years.
