x 3115
x 3419
Rode it to work again. Above average temps here in Central PA. News this morning said this January could break into the top 10 for warmest January on record. I'm not complaining.
rgb
FJRModel: 2015
x 20
x 49
Post by rgb »
El Toro Joe wrote: Mon Jan 27, 2020 8:44 pm Nice...my dad use to let me fly the lawnmower around the yard, when I was a kid...
??? The only lawnmower my dad trusted me with was a gas powered reel mower that took about three times as long as it should have to do the lawn. I am in awe.
x 10996
x 4232
rgb wrote: Wed Jan 29, 2020 11:44 am
...gas powered? We had a push powered reel mower...the kind without the gas engine.
Spininprop
FJRModel: 2022ES
Sold 2000 Bandit 600
x 972
x 833
Post by Spininprop »
Received supplies for the major PM work planned for the fjr. Starts 3:00pm Friday. 16000 mile maintenance, plus plugs, oil and filter change.
BkerChuck loved this
Spininprop
FJRModel: 2022ES
x 972
x 833
Started the 20,600 mile service :>)
Just pulled the ujoint, a little rust on the splines but nothing unusual. Cleaning all parts as i go, lube before i reinstall. Getting close to pulling the swingarm.
x 15843
x 14952
Severe Clear tomorrow, high 61 degrees.
Bike ready? Check
Gear ready? Check
Camera battery charged? Check
Uh... yeah, no brainer baby!!!
danh600 loved this
Spininprop
FJRModel: 2022ES
x 972
x 833
Swingarm bearings ok, not a lot grease but all looks good. Greased the swingarm and cleaned it. Thats done. Debating the best way to tackle getting the center stand bolt cutoff and lubing the bearings. But that is tomorrows job.
Hack
x 1091
Post by Hack »
Spininprop wrote: Fri Jan 31, 2020 10:18 pm Debating the best way to tackle getting the center stand bolt cutoff and lubing the bearings.
I used my Sawsall reciprocating saw... With a fresh, fine toothed metal cutting blade it took all of 14.5 seconds to cut the bolt(s).
x 15843
x 14952
Hack wrote: Sat Feb 01, 2020 10:30 am
I used one of these, with the blade designed for metal. with a little oil and patience, it worked beautifully.
https://www.lowes.com/pd/Bosch-Starlock ... &gclsrc=ds
x 48404
x 20490
Living his forum name!
ionbeam loved this
Hack
x 1091
Post by Hack »
Hppants wrote: Sat Feb 01, 2020 10:48 am
Damn... I have a similar tool.
'Never occurred to me to try it.
Hack
x 1091
Post by Hack »
wheatonFJR wrote: Sat Feb 01, 2020 12:38 pm
I rode it to a friends house so he could show me how a proper plug change and throttle body sync is performed. Learned a lot.
CollingsBob
FJRModel: 2024 BMW R1300 GS
x 6412
x 2794
Post by CollingsBob »
I transferred the bracket for the Garmin from the dash shelf to the handlebar mount that I’ll be using on the rental bike.
gixxerjasen, wheatonFJR, and bill lumberg loved this
x 15843
x 14952
200-ish miles today by myself. Weather was great. Went to the drag strip and watched a pretty good bracket race. Had fun today.
bigjohnsd, ionbeam, and CollingsBob loved this
fjray
FJRModel: 04
x 217
x 1207
Post by fjray »
The FJR got to watch while I took the wing apart for major service. You haven't lived until you do the air filter in a wing.
x 12948
Ray, I have lived!! Fun job fer sure!
x 6276
x 10349
fjray wrote: Sun Feb 02, 2020 5:21 pm The FJR got to watch while I took the wing apart for major service. You haven't lived until you do the air filter in a wing.
Worse than an AE FJR?
x 10996
x 4232
I rode it to work...suppose to be 55 and sunny for my ride home. :D :D :D
x 3115
x 3419
Rode mine to work as well today. Forecast high of 60 this afternoon means I'm hoping to give it a good bath after work.
