x 4139
x 4636
I like that jug. You got a model number? Do you have it plumbed or do you just drink at stops?
danh600 wrote: Mon Jan 13, 2020 9:34 am I purchased the water jug holder from Garuld awhile back. The bracket is very nice, but the igloo jug is not that great for hot Florida riding. The ice seemed to melt too quick. Well, the problem took care of it's self. I didn't screw the lid back on good and it flew off. So the jug needed to be replaced.
This time I went with a half gallon Rtic jug. Looks better and should hold ice better. The bracket base is a little big for it, but the clamp holds the jub tight.
Now it looks like it was always part of the bike.
Took the bike for a couple of rides this weekend. Just short morning back roads rides.
x 2189
x 2968
Replaced the exhaust pipe on the left side. It was dented from a parking lot drop by the previous owner. Got a set off another forum from a 2016. Pretty easy swap out. Also, touched up the scratches on the left side mirror, from that drop, with a colorrite pen. Once cured well, I will polish with an air polisher and compound. Getting ready for the Frosty Balls Ride.
bill lumberg and El Toro Joe loved this
x 3037
x 3380
Same thing I did to it yesterday, rode it to work. Mild temps so far this month but I know it won't last. Going to enjoy it while I can.
x 5988
x 10130
bill lumberg wrote: Tue Jan 14, 2020 8:47 pm I like that jug. You got a model number? Do you have it plumbed or do you just drink at stops?
It's this one.
https://www.rticcoolers.com/shop/drinkw ... -Stainless
1/2 Gallon Rtic Jug. I picked the stainless steel, but they have other colors.
It hasn't been Florida summer tested but I think it's going to work very well. I have not plumbed mine yet. Looks like it would be easy to do because the top is plastic not stainless. I don't ride that hard and tend to stop from time to time. I might not plumb it. If I start planning a long hot trip I might change my mind.
The dimensions are a little small for the bracket on the half gallon, but a little big on the one gallon. The half does work cause you can tighten up the clamp. Mine rides fine and doesn't rattle.
The Ozark Trail jugs sold at Walmart are very good too. I have a small one and it holds ice water for days. They make a 1/2 and one gallon one also. I can't seem to find the dimensions online.
I would rather have a one gallon, but 1/2 works.
x 4139
x 4636
Swapped the V47 for the V56. Between cold weather gear and range gear, need all the space I can get this time of year. Shook my heated and insulated stuff. Winter is arriving here in a few days.
x 4139
x 4636
They come in matte blue. Nice find Dan.
danh600 wrote: Wed Jan 15, 2020 9:23 am
It's this one.
x 10721
x 4123
Put it back in hibernation...the weather is gonna urn back to shit, for the next week or so
Hack
x 1079
Post by Hack »
Inspected and re packed the steering head bearings...
x 47194
x 20055
Hack wrote: Thu Jan 16, 2020 2:56 pm Inspected and re packed the steering head bearings...
Make sure you test them to FJR nominal speeds. You don't want to have an issue on a long trip.
<snerk>
Hack
x 1079
Post by Hack »
wheatonFJR wrote: Thu Jan 16, 2020 3:33 pm
<snerk>
CollingsBob, escapefjrtist, and wheatonFJR loved this
Hack wrote: Thu Jan 16, 2020 5:52 pm
<snerk>
Photoshop. Everyone KNOWS shaft drive motorcycles can't wheelie. ;) And, wheelies set down hard have no effect on steering bearings.
Uncle Hud, ice_station_zebra, Toter and 2 others loved this
x 4139
x 4636
Changed the front brake pads. First time I’ve ever changed the pads myself on either of the FJR’s I’ve owned.
Dshane, Hppants, philharmonic and 1 others loved this
x 15230
x 14090
I'm a 90% front braker. I changed the front pads on my Gen 1 and my current Gen 3 at 50K. Interesting how one pad at each pair of pistons wears a lot more than the other.
I'm at 62K now and the rears are still only 1/2 worn.
x 908
x 2660
Hppants wrote: Sat Jan 18, 2020 10:52 am I'm a 90% front braker. I changed the front pads on my Gen 1 and my current Gen 3 at 50K. Interesting how one pad at each pair of pistons wears a lot more than the other.
I swap inner/outer at about mid life on the gen II front pads. On the right, the pair linked to the rear brake wears more slowly than the pair activated by the rear brake (linked braking). If you are getting a very large difference between inside/outside (or top/bottom pairs on the left side) you might want to have a look at your pistons/seals and/or the slider pins.
x 6073
x 10022
I think it's been since before Christmas since I had the FJR out. I had to go meet a friend this morning to get some stuff from him way over in Arlington. All slab on I-20 but I was out riding, the rain has passed, it was 60F and sunny, and I was on two wheels. Old reliable fired right up ready to go.
BkerChuck and Hppants loved this
x 47194
x 20055
Leaving in 30mins to go eat some breakfast and ride around in circles in NGA
Dshane
FJRModel: 2018 FJR 1300A
x 54
x 25
Post by Dshane »
Added some Garuald brackets and pegs. Haven't used them yet, just got 5 inches of that white stuff last night.
x 15230
x 14090
FJRoss wrote: Sat Jan 18, 2020 11:21 am
Yeah - I've cleaned and dry-lubed the pins. Use a toothbrush to remove as much crud from the exposed pistons before pushing them back in on tire changes. I thought about swapping the pads mid-way, that is a good money saving idea. I did keep the old pads, so now I really have a spare set that I could use in the future. I didn't change the linked pads on the front - they were like almost new at 50K. Again, almost all of my braking is with the front wheel. I really only use the rear if I'm braking real hard and want to keep the bike straight. I've seen "trail braking" with the racers, but I don't think I'm quite up to that particular skill set...
x 3037
x 3380
Snow and crap we got on Saturday was all cleared from the roads by Sunday afternoon so I managed to ride to work this morning. 26 degrees out and fairly windy but heated gear saves the day. I think I'm likely warmer riding to work with the jacket liner and heated gloves than if I drove my truck that sits outside all night. Coworkers just think I'm nuts.
Spininprop and El Toro Joe loved this
x 4139
x 4636
Rode it to work. It was so cold on the way home, when I went in the grocery store to get an ingredient I needed to make chili when I got home, I flipped the chin bar up, but kept my Neotec 2 on.
