Red wrote: Wed Nov 27, 2019 2:20 pm ]Uncle Hud,
~~ Plug it in, plug it in . . . ~~
I know, too late; sorry. :geek:
Not too late and I always appreciate suggestions.
I've had a plug-in since the day the bike came home, but it intruded into the glove box and left less space for my kickstand pad and paperwork -- registration, insurance, emergency contacts, etc. The USB now sticks out less than 1/4-inch into the glove box, and (thanks to 15 minutes with a small rasp) it doesn't look bad at all.
x 3519
x 12943
Looked around for the FJR, couldn't find it... oh yeah, it's not here any more... so tinkered a bit with a CB650SC and an ST1300 currently residing here. CBF is off to the side being neglected.
x 15840
x 14948
Had a few Nighthawks, Ray - they are simply awesome bikes. Did not have a 650, but when I was in high school, I lusted after that bike bad. 12 second quarter mile for a 650? Oh yeah, baby!!
x 6387
Washed the SFO off of it, for the RTE tomorrow. :roll:
x 6239
x 10404
Left the FJR behind.
Riding the Valkyrie tommorow to the FJR RTE. :-P
x 6387
danh600 wrote:Left the FJR behind.
Guess you’ll bring up the rear then. Image
x 48396
x 20486
LKLD wrote: Fri Dec 06, 2019 11:06 pm
The BIG rear tire!
Dshane
FJRModel: 2018 FJR 1300A
x 54
x 25
Post by Dshane »
Added Delkevic 13" slip-ons. But still locked in winter so far, waiting for some snow to melt to take Freedom 17 out for a test ride.
x 48396
x 20486
Nothing but ordered front and pillion seats from Russell. If the ortho doctor says all things look good, I will prep it for a ride on the first good dry day of riding.
bill lumberg and Full House loved this
x 5032
x 6767
wheatonFJR wrote: Sat Dec 07, 2019 2:46 pm Nothing but ordered front and pillion seats from Russell. If the ortho doctor says all things look good, I will prep it for a ride on the first good dry day of riding.
You will love the Russell. I have had them on all my bikes going back to the mid '80s. I even have one on my DR, it was not bearable without it.
x 48396
x 20486
fontanaman wrote: Sat Dec 07, 2019 3:01 pm
I had a Russell on my 04 that my son now enjoys. I had a Laam on my first 13, not as good as a. Russell, but certainly good enough for the riding I do. Im paying for the higher priced vendor just because I just liked the customer experience on the Russell...plus, it is a slightly more comfy seat on the continental sized rides I plan on doing.
Hack
x 1091
Post by Hack »
'Bought a couple of M5 0.8x16mm socket head bolts to replace the OEM bolts on my side-stand sensor... In anticipation of a future stand/swing arm maintenance session.
x 5032
x 6767
In the middle of a valve check. Taking a lunch break.
Hppants, escapefjrtist, and wheatonFJR loved this
x 5032
x 6767
Well today I got lucky, no not that way! None of my valves needed adjustment after about 21k since the last service. At the last service some of the valves needed adjusting.
I managed to do this without pulling off side plastic. To find top dead center for each cylinder I got a bit creative.
When the holes in the camshaft are aligned with marks shown in the photo the number 1 cylinder is at top dead center and #1 cam lobes are at 10 and 2 o'clock.
I measured the #1 cylinder intake cam lobe distance to the edge of the cylinder head, it was about 10/32. See photo.
All I had to do was move the rear tire until the next set of lobes were at about 10 and 2 then measure the distance. Measuring it took some of the eyeballing it out of the process.
x 3519
x 12943
While bumping it along with the rear tire is OK, why not just remove the inspection plug on the right timing cover and turn the engine with a 14mm socket.... more control?
czimmer
FJRModel: 2015 FJR1300A
Post by czimmer »
Air filter
Spark plugs
Oil change and filter
Final drive oil
Wash
Wax
Weekly bike checks including tire pressures, fluid levels, and wiping down the fork tubes with WD40.
IBA# 78859
2015 Yamaha FJR1300A
2001 Honda ST1100A (wife's)
2002 Honda ST1100A (daughter's)
x 5032
x 6767
raYzerman wrote: Sat Dec 07, 2019 9:45 pm While bumping it along with the rear tire is OK, why not just remove the inspection plug on the right timing cover and turn the engine with a 14mm socket.... more control?
I did not have to remove the fairing side panel. I have a Gen II. On Gen III's i think the inspection plug is accessible w/o panel removal.
x 3519
x 12943
No fairing removal required, just a couple of screws and pull it out to access the inspection plug. Similar deal with Gen3 but there is no inspection plug, have to remove the entire right timing cover. If adjustments needed you have to remove the right timing cover anyway... but no need to remove the fairing.
x 15840
x 14948
On the Gen III, the timing cover has no "inspection plug". You have to take the cover off to turn the crank by the crank bolt. However, you don't have to remove the side fairing plastic to take the cover off. You have to remove 2 of the bolts and you can pull it out enough to get to the timing cover bolts. That was one difference from the Gen 1 that I didn't like.
Jim - that is an interesting way to ensure TDC. Of course the cam cover arrows and the dot on the cam is documented in the FSM as a way to check.
I'm from the camp that believes that entire side of each cam lobe (the side where the valves are not touching the cam) is a perfect semicircle. In other words, it should not matter where within that semi-circle you check the gap. It will be the same. Now, I don't know if I can prove it, but during the last check on my bike, for shits and giggles we checked the gap at about 3 points within that semi-circle. And then checked it using the timing marks with the cover off. At least as far as a "go/no-go" feeler gage can measure, there is absolutely no "feel-able" difference.
Now that the motor is in good shape, time for the Relay Arm service?
I largely ignored it. Checked mileage and confirmed oil can wait until next weekend. Used a knife tip to spread the connectors on my 595LM. Took 30 seconds. Damn. Turns out the battery is fine. Now I don’t have to stand at the bike when I’m putting in destinations. Thanks internet! Put my “made by Shoei in the USA” (but ordered and received from Japan) mirrored blue visor on my Neotec 2. Fiddled with the wires on my newly installed Sena 20s Evo on my RF-1200.
About to perpetrate dcarver’s pairing order to see what happens. ETA-And the 595 wins. It won’t play nice under any circumstance. So I rode the bike to the park for a 2 mile run. Or what passes for a run for me, anyway.
